where air meets water
Gallery
Username
Password
May 25, 2013, 03:36:55 AM
Welcome,
. Please
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Help
Scenic City Volks Folks Forums
Tech. Center
Air-Cooled VW Tech
vw bug mid engine
Print
Author
Topic: vw bug mid engine (Read 558 times)
mrcoffee
Offline
vw bug mid engine
January 01, 2012, 07:40:18 PM »
can a normal rear engine chassis be modified to a mid engine configuration?
attack chicken
Offline
Ooltewah
Re: vw bug mid engine
January 01, 2012, 10:09:31 PM »
It could be, but there would be lots of fab. work. You will pretty much just have to "back half" the pan. May be easier to just make a tube pan designed with mid engine in mind. Otherwise you pretty much have to figure out where you want the rear wheels and measure forward on the pan the length of the engine and transaxle from the diff. Mark the pan and chop it off. You may be able to use many of the factory parts and set up the rear suspension with coil over shocks, that would allow for the removal of the torsion tube. I would imagine you could do a setup like a formula V or a mid engine sand rail modded for a street car. Then you have to deal with clutch and shifter linkage. Probably just a hydraulic clutch master and slave setup but getting a good shifter feel could be a little more difficult. I've done it on a late model Corvair but thats apples and oranges..unibody vs pan based and the differential stayed in the "factory" location, everything else moved around it...still, lots of fab work to say the least.
Offline
January 01, 2012, 11:06:36 PM »
If you place the engine in front of the transmission(Form-V) you will have to "flip" the ring gear from one side to the other side of the tranny case or you will end up having 4 rev's gears and 1 forward gear. Not a good thing. Easy to do on a swing axle tranny with 2 side cover plates (61-68). A much more difficult on the IRS (69-up)
Print
Jump to:
Please select a destination:
=> General Discussion
=> Upcoming VW Events
=> Road Stories
=> Collectors' Corner
Site News and Such
=> Welcome Newcomers
=> Forum Help, Errors, and Questions
=> VW Rides, Builds, and Projects
=> All Other Projects
=> Gatherings and Events Photos
Tech. Center
=> Air-Cooled VW Tech
=> Water-Cooled VW Tech
=> Non-VW Tech
=> VW Autos For Sale
=> VW Parts and Accessories For Sale
=> Non-VW Classifieds
