74loaf
Club Members
Inhabitant
OfflineHixson, TN
« on: January 14, 2012, 08:07:59 PM » |
 So this is why the valve wasnt coming back out... is this fixable or do I just need to get a new head?
« Last Edit: January 14, 2012, 08:09:49 PM by 74loaf »
Bignick
Secretary
Club Officers
Needs Sleep
OfflineChattanooga
« Reply #1 on: January 14, 2012, 08:22:20 PM » |
On an intake? That seems weird. What's your plan?
74loaf
Club Members
Inhabitant
OfflineHixson, TN
« Reply #2 on: January 14, 2012, 08:28:23 PM » |
well, I'm guessing there is no way make that stay in the head now that it has come loose... so I suppose I'll look around for a new 2.0 head. Sucks cause otherwise this head did look really nice (aside from the GEX  stamped into it under the valve cover)
Club Members
Won't Go Home
OfflineChattanooga Tn.
« Reply #3 on: January 14, 2012, 09:32:58 PM » |
well, I'm guessing there is no way make that stay in the head now that it has come loose... so I suppose I'll look around for a new 2.0 head. Sucks cause otherwise this head did look really nice (aside from the GEX  stamped into it under the valve cover) Welcome to Type -4 engines. This is what they do. This why I love them so much  It is unusual for a intake seat to fall out but I have seen a lot of them do it along with the more common exhaust seat. You won't get it fixed around here. I would not trust a used up head either. You already have one of them now. If you can get a Federal Grant you could buy a Jake Raby head. I would just about bet there isn't 5 people in the USA can make a type-4 valve seat STAY in the head . The factory couldn't do it
« Last Edit: January 14, 2012, 09:36:30 PM by Ret.Bugtech »
Club Members
Won't Go Home
« Reply #5 on: January 15, 2012, 10:21:33 AM » |
I think Hoffman does the engineering for Raby's heads . Not cheap as Russ says .
sunnybug84
Club Members
Neophyte
OfflineUlm/Germany
« Reply #6 on: January 15, 2012, 09:08:14 PM » |
If it is that expensive over here, you might wnat to take a look in germany? I know at least 3 or 4 people who can actualley fix heads like that easily.  If you want me to, I will ask them. Shipping is pretty bad with arround 150 back and forth put the repair itself is not tooo expensive compared to a $1000 head.  typ4 are a lot more common at home.
74loaf
Club Members
Inhabitant
OfflineHixson, TN
« Reply #7 on: January 15, 2012, 10:36:32 PM » |
naa, I'll just put the bus on the backburner for now... I just picked up a new toy today anyways...
ASBug
Club Members
Needs Sleep
OnlineVarnel, Ga
« Reply #8 on: January 16, 2012, 07:29:27 AM » |
When I get the stuff from Rick, I'll see what is in there. Will a 1.7 head work? Thanks, KC
attack chicken
Inhabitant
OfflineOoltewah
« Reply #9 on: January 16, 2012, 08:01:45 PM » |
The 1.7s will work after they are cut for the larger cylinders, also have smaller valves and different chamber shapes, but good to go otherwise. Here is a link to some info... http://www.tunacan.net/t4/tour/heads.shtml
Club Members
Won't Go Home
« Reply #10 on: January 16, 2012, 09:51:13 PM » |
The 1.7s will work after they are cut for the larger cylinders, also have smaller valves and different chamber shapes, but good to go otherwise. Here is a link to some info... http://www.tunacan.net/t4/tour/heads.shtmlAs I remember ,the 1.7 didn't have the valve seat problem near as often . The 1.8 engines were a little worse with the 2.0 topping the list as the sorriest p.o.s. All of them loved to burn a gap in the shim between the head and cly ending up torching a groove through the head. We won't talk about exhaust port studs. I think the 1.7 was the best type-4 engine if you got rid of those terrible carbs(2). Just my opinion.
