where air meets water
Gallery
Username
Password
May 24, 2013, 05:20:04 PM
Welcome,
. Please
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Help
Scenic City Volks Folks Forums
Tech. Center
Air-Cooled VW Tech
Drag link replacement
Print
Author
Topic: Drag link replacement (Read 650 times)
Offline
May 02, 2012, 10:34:04 AM »
I took my bus to Doyle's Alignment shop in Ft. O yesterday and had the front end aligned. It drives a whole lot straighter now but there's still a lot of play in the steering wheel. I had a tie rod that was slightly bent and he was able to straighten it out a bit. He also said my drag link is completely worn out and that is most likely the source of my steering wheel slop. He said I could replace it and it wouldn't affect the alignment. Is this something I can do myself or do you need special tools and a lift? Looks like you can get new drag links for about $55, which isn't too bad.
Brian
Offline
Smyrna, TN
Re: Drag link replacement
May 02, 2012, 11:48:08 AM »
I had to change my drag link on both Mack and Mo. Both had a lot of play in the steering and it tightened them right up. Doyles was the one that discovered Macks was sloppy. Its not hard to change. I've got the tools so when you get the new one in let me know and I'll help.
Offline
May 02, 2012, 01:21:48 PM »
Thanks, Brian! If you're at CYW this weekend we can talk more about it then.
Offline
May 02, 2012, 07:36:44 PM »
I changed Homer's drag link many moons ago . . . If I remember correctly, I didn't even have to jack it up. It's about like changing a tie-rod. It doesn't affect the alignment, but it can affect the position of the steering wheel.
74loaf
Offline
Hixson, TN
May 06, 2012, 10:18:35 AM »
Russ, its easy to do. That was one of the first things I had to do to my bus when I started driving it. its just 2 castle nuts, then lay the old one next to the new one and make sure they are the same length, then bolt the new one on and your done! there is a cover that goes over all that but its like 6 bolts to remove. Very simple.
Offline
May 26, 2012, 11:20:30 PM »
Well with Money and Robert's help tonight, we got the drag link replaced. Wow the steering feels so much better, it's like a new bus. And with the alignment done it drives pretty straight too.
moneybags
Offline
May 26, 2012, 11:35:20 PM »
Well, Loaf helped. All I did was beat on stuff...
Print
Jump to:
Please select a destination:
=> General Discussion
=> Upcoming VW Events
=> Road Stories
=> Collectors' Corner
Site News and Such
=> Welcome Newcomers
=> Forum Help, Errors, and Questions
=> VW Rides, Builds, and Projects
=> All Other Projects
=> Gatherings and Events Photos
Tech. Center
=> Air-Cooled VW Tech
=> Water-Cooled VW Tech
=> Non-VW Tech
=> VW Autos For Sale
=> VW Parts and Accessories For Sale
=> Non-VW Classifieds
